Conf call with softphone
Hello Guys,
I am not able to make conference call using my IP communicator. The conf call with IP Phones works fine. I have exactly the same config of Partition and CCS in the softphone as I have with IP Phone but not able to make conf call. Any help would be greatly appreciated.
BT
6 Replies 6
e.huntley
Is you device pool correct. Make sure that you are not using a region that is not pure G.729 to the conference bridges and/or don't have access to a transcoder
Thanks Eric for the reply. When I configure the Softphone to use the DP in the region using G.711 the conf call works but when I change the DP to the resion with G729 it doesn't. I don't have ant configured transcoder in the CCM. Below is the output of sh diag for the GW. Do I need to configure it in the rotuer? If so, could you please let me know how can I do that?
If you are using a Software Conference Bridge (the one configured only on the CCM) then that is the problem since the SCB only supports G.711. You will need to configure a Hardware Conference Bridge on the router and associate it to the CCM server. From what I have read that is your problem. Here is some info on how to setup the HCB:
1.- Make sure to put the 'dsp services dspfarm' command on the voice-card that is being used:
AVVID2(config)#voice-card 1
AVVID2(config-voicecard)#dsp services dspfarm
on a show run you should see something like this:
voice-card 1
2.- Configure the interface that is going to talk using skinny protocol with the CCM server:
for example:
AVVID2(config)#sccp local FastEthernet0/0
Enable sccp in the router:
AVVID2(config)#sccp
3.- Point the router to talk sccp with the CCM server
sccp ccm identifier version
for example:
AVVID2(config)#sccp ccm 192.168.4.10 identifier 27 version 3.3
4.- Create a sccp group:
You will associate this group to the identifier from step 3 and will assign a priority to the group.
AVVID2(config)#sccp ccm group 27
AVVID2(config-sccp-ccm)#associate ccm 27 priority 1
5.- Create a dspfarm profile:
In here you will specify if its going to be a conference, transcoder or mtp:
AVVID2(config)#dspfarm profile 27 conference
Then you will associate the profile to the skinny application:
AVVID2(config-dspfarm-profile)#associate application sccp
Enable the dspfarm profile
AVVID2(config-dspfarm-profile)#no shutdown
6.- Associate the ccm group to the dspfarm profile
AVVID2(config-sccp-ccm)#associate profile 27 register CFBMAC
Note: CFBMAC is a name that you gave to the HCB and MUST be the same as in the CCM server
//Jorge
Sorry, I forgot to paste the output of sh diag. I also added the sh running for your review.
I am uploading the config and the output of the sh diag. I seems like either I don't have the right hardware or the config is no right. Could you please let me know if I have the right config/hardware to make the conf call using softphone work?
Again, I forgot the attachement. Here it is
