08-08-2009 12:38 AM - edited 03-18-2019 10:30 AM
I have CME 7.1 and I need to implement conference calls up to 8 calls. So I added the following command:
max-conferences 8 gain -6
but I am not able to make conferences for more than 2 parties.
Shall I use conference bridge?
I have also the same problem with Music on hold, I used the command:
moh music-on-hold.au
but it does not work.
So any body can help me??
Solved! Go to Solution.
08-08-2009 05:27 AM
Note, moh is sent to external calls only. And, .AU files good for the router are difficult to produce, so just try the default file to begin with.
Please remember to rate useful posts with the scrollbox below.
08-08-2009 03:03 AM
You need to follow the conferencing chapter in the administration guide, the configuration is explained there.
08-08-2009 04:51 AM
thank you, but what about moh
I already have added the file (music-on-hold.au) to flash and under telephony service I added:
08-08-2009 05:27 AM
