config request
kailash_sharma
I need to configure a side car ( expansion module ) in CME . can anyone please tell me the configuration commands for the same . this is my current config .
ephone-dn  168  dual-line
number 0152
label rrrrrr x0760
description rrrrrr
name rrrrrrrrr
mobility
snr calling-number local
call-forward busy 0799
call-forward noan 0799 timeout 32
ephone  10
device-security-mode none
description rrrrrrrr
mac-address D0C2.8243.3C6F
ephone-template 12
username "rrrr" password hhhhhh
  type 7962
button  1:168
Thanks in advance
KS
TunNyuntMoe
type 7962 addon 1 ?
follow above cmd and I hope you can figure out
No this is not working.
Try this in ephone 10
type 7962 addon 1 7914
(7914 is the model number so it could be 7915 or 7916)
Hope this helps.
Thanks it works fine .. Cheers !!!
