09-20-2011 11:34 AM - edited 03-16-2019 07:05 AM
Client is upgrading from 8.0.3 on MCS to 8.5 on UCS. I know that I must disable EM when upgrading but does the DRS backup retain their current logged in phone or will they have to login again?
Thanks!
Solved! Go to Solution.
09-20-2011 09:08 PM
As long as there is upgrade then the phones will perform firmware upgrade when register with new cm and then the EM login will be required
Hope this help
If helpful rate
09-20-2011 09:08 PM
Hope this help
If helpful rate
