CUCM 9.x bug/Feature:: Modify Button Items
Hello There,
When attempting to “Modify Button Items” on a Device Profile, once you click the button and the pop up window comes up, the main page refreshes as a Cisco 9951 rather than the Device Profile it should be.
I has been checked 9.x three difference version all have same behaviour. I am not sure is it bud or something else.
I am attaching the Screen shot as a reference.
Is any one know the reason or face the same issue.
Ryhan
Rob Huffman
Hi Ryhan,
Just to add a note to the good tips from my buddy Aman (+5 smiley)
Can you check this bug;
UDP converts to a phone if we "Modify Button Items" on UDP
CSCug75461
Cheers!
Rob
6 Replies 6
Aman Soi
Hi Ryhan,
Did u try changing the browser?
regds,
aman
I tried with Different Browser but no luck mate.
Muhammad
Hi Rob,
You are simply Gr8.
I was trying to look for the bug but could not.
regds,
aman
Rob Huffman
Hi Ryhan,
CSCug75461
Cheers!
Rob
Thanks Rob,
You save my day.
Really appropriate the effort of   Rob and Aman.
Hi Ryhan,
You are most welcome my friend smiley
Cheers!
Rob
