10-01-2009 01:07 PM - edited 03-18-2019 10:41 AM
Wanted to ask a simple question.
When the a cluster has for example 2 subs and a pub, to configure a user one can login to any server and perform the change since database is common? Or whats the common practice?
10-01-2009 01:20 PM
If you mean configure a user to access CUCM admin it doesn't matter where you create it, it can access any server in the cluster
java
if this helps, please rate
10-01-2009 04:05 PM
Thanks.
Same thing should be true for configuring phone too ? For user on sub-2 being configured from sub-1.
10-01-2009 05:48 PM
Yes, same thing for phones.
That's the whole concept of having a cluster, whatever you configure in 1 server replicates to the others
java
