CUVA site-to-site
recep.sefer
I have two CME sites connected by VPN and H.323
CUVA does not work accross two sites
Please Help
5 Replies 5
gogasca
Level 10
Level 10
Are you allowing all IP traffic?
Any inspection performed in the VPN tunnel?
which devices you use for the tunnel ?
I am allowing all IP traffic
No inspection
I am using cisco 2851 routers on both sites
I want to learn How CUVA works?
Which TCP/IP ports does it use?
Here is my config
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service h450.2
no supplementary-service h450.3
supplementary-service h450.12
h323
sip
registrar server expires max 3600 min 3600
crypto isakmp policy 1
hash md5
authentication pre-share
lifetime 3600
crypto isakmp key 12345678 address x.x.x.x
crypto ipsec transform-set cm-transformset-1 esp-des esp-md5-hmac
crypto map cm-cryptomap local-address GigabitEthernet0/1
crypto map cm-cryptomap 1 ipsec-isakmp
set peer x.x.x.x
set transform-set cm-transformset-1
match address 100
qos pre-classify
class-map match-all STREAMING-VIDEO
match access-group name GUVENLIK-KAMERA
class-map match-all BULK-DATA
match ip dscp af11 af12
class-map match-all INTERACTIVE-VIDEO
match ip dscp af41 af42
class-map match-all VOICE
match ip dscp ef
class-map match-all MISSION-CRITICAL-DATA
match ip dscp 25
class-map match-all SCAVENGER
match ip dscp cs1
class-map match-all NET-MGMT
match ip dscp cs2
class-map match-any INTERNETWORK-CONTROL
match ip dscp cs6
match access-group name IKE
class-map match-any CALL-SIGNALING
match ip dscp cs3
match ip dscp af31
class-map match-all TRANSACTIONAL-DATA
match ip dscp af21 af22
policy-map QOSBASELINE-V3PN-EDGE
class VOICE
priority percent 18
class INTERACTIVE-VIDEO
priority percent 15
class CALL-SIGNALING
bandwidth percent 5
class INTERNETWORK-CONTROL
bandwidth percent 5
class NET-MGMT
bandwidth percent 2
class MISSION-CRITICAL-DATA
bandwidth percent 10
queue-limit 6 packets
class TRANSACTIONAL-DATA
bandwidth percent 5
queue-limit 3 packets
class STREAMING-VIDEO
class BULK-DATA
bandwidth percent 4
class SCAVENGER
bandwidth percent 1
queue-limit 1 packets
class class-default
bandwidth percent 25
queue-limit 16 packets
interface Loopback0
ip address 10.1.10.2 255.255.255.0
interface GigabitEthernet0/0
ip address 192.168.0.200 255.255.255.0
no ip mroute-cache
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 192.168.0.200
interface GigabitEthernet0/1
bandwidth 5000
ip address x.x.x.x 255.255.255.240
ip access-group 150 in
ip access-group 150 out
duplex auto
speed auto
service-policy output QOSBASELINE-V3PN-EDGE
interface Service-Engine1/0
ip unnumbered Loopback0
service-module ip address 10.1.10.1 255.255.255.0
service-module ip default-gateway 10.1.10.2
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 x.x.x.x
ip route 10.1.10.1 255.255.255.255 Service-Engine1/0
ip route 192.168.1.0 255.255.255.0 192.168.0.1
ip access-list extended GUVENLIK-KAMERA
permit tcp any eq 5100 any
ip access-list extended IKE
permit udp any eq isakmp any eq isakmp
access-list 100 permit ip 192.168.0.0 0.0.0.255 192.168.2.0 0.0.0.255
access-list 100 permit ip 10.1.10.0 0.0.0.255 192.168.2.0 0.0.0.255
access-list 100 permit ip 192.168.0.0 0.0.0.255 10.2.10.0 0.0.0.255
access-list 100 permit ip 10.1.10.0 0.0.0.255 10.2.10.0 0.0.0.255
access-list 100 permit ip 192.168.1.0 0.0.0.255 192.168.2.0 0.0.0.255
access-list 100 permit ip 192.168.1.0 0.0.0.255 10.2.10.0 0.0.0.255
telephony-service
sdspfarm units 4
sdspfarm tag 1 mtp00097c5e9ce0
conference hardware
video
maximum bit-rate 512
no auto-reg-ephone
em logout 0:0 0:0 0:0
fxo hook-flash
max-ephones 96
max-dn 192
ip source-address 192.168.0.200 port 2000
I have the video call working fine between two CME sites.
I have CME 4.2 with following Config
#voice service voip
h323
h323 slow start
#telephony-service
service phone videoCapability 1
(videoCapability keyword is case sensitive)
#ephone 1
video
Would you be able to post your config? I am having a similar issue.
Mark
If two CUVA are in the same subnet, NO PROBLEM.
If they are connected through IPSEC VPN, there is no video.
