08-05-2015 07:38 AM - edited 03-17-2019 03:53 AM
I recently install a SIP trunk to a UC540.
Inbound call working fine.
For outbound calls the ITSP requires me to insert country code and drop the leading zero for national/domestic calls. I currently use 9 for outside line access
Has anyone ever created a dial peer to do this?
08-05-2015 08:13 AM
Simply configure translation rules to do what you mention, there's plenty of material on cisco.com about the topic.
08-05-2015 09:46 AM
what is the number pattern you dial-out for domestic and national calls. based on that you can create dial-peer. as java said there n of document available in respect translation rule. however just share number pattern you dialing out for national and domestic.
08-06-2015 12:52 AM
for example to a mobile number
9 for outside line then 08[3456789]XXXXXXX
need that to be 3538[3456789]XXXXXXX
