Display Caller Name for incoming calls
f.giordano
Hi all,
Is there a way to establish a relation between a Caller Number and a Caller Name. If an incoming call comes to the H323 gateway, I'd like to display a name instead of the number on the IpPhone.
Is it possible to edit a txt file for instance that will be check for every incoming call in order to match a name or something like that ?
Thx all
Fabian
10 Replies 10
paolo bevilacqua
Are you using CM ?
I wrote a TCL/IVR service "number2name" that does that. It can be acquired on ciscoscripts.com
Hi Paolo,
Yes customer is using CCM 4.1(3) with H323 gateway. I'm going to test it first in our lab environnement and I'll keep you informed.
Thx for it.
Fabian
P.S: Next star colour is not so far for you now :p
Me again.
It doesn't work ( Phone doesn't ring ). I kept the current dial-peer voice. Just add the service num2name. Is there anything to do on the CCM ?
Here is part of the config:
dial-peer voice 300 pots
description TEST TCL
service num2name
incoming called-number 54XXXXX
direct-inward-dial
port 0/1/0:15
application
service num2name flash:/number2name.tcl
param list-file flash:/bulklist.txt
Here is the bulklist.txt
1, 691915602, FabianMobile
Debug voice application in attachment.
If you need more info to help, don't hesitate.
Thx again.
Fabian
Tried to do the exact same thing with a local .txt file on the flash, did the same config as you did. I cant receive calls either, did u get it working ?
Considering that I'm the one that wrote and mantains these scripts, you can contact me at the address present in my profile for professional help.
Hi Paolo,
We are trying this on our inbound SIP dial peer but it does not seem to work. Instead ot appears to stop calls coming in completely. If we try the same service on a POTS dial peer it works.
Is there something that will stop this working on an inbound VOIP DP?
Oli
Did you purchased the script on my site? If so, when ?
Hi Paolo,
This was purchased from your website yes.
It was a colleague of mine that purchased this from our company name (Axonex).
It would have been approx 3 years ago.
Oli
I've received your email and will try to assist as I do with all my customers.
Thanks.
