display capability for 7961 & 7941 for user search
glenox
Does anyone know the maximum number of users that can be displayed in a directory search for a 7961/41 phone?
Rob Huffman
Hi Geoff,
The maximum number is 64. This parameter is configurable on CCM;
To limit the search time for accessing users in the corporate directory and to reduce overhead for Cisco CallManager, set two enterprise parameters. The parameters apply to the user search from the Cisco CallManager User window and from the Cisco IP Phone directories button.
Enable All User Search - This parameter specifies True by default. The False setting requires that a user search the corporate directory by entering search criteria (e.g., first name, last name, DN).
User Search Limit - By default, this parameter specifies 64 search results at a time (the range is 1 to 64 search results). This parameter remains invalid if the Enable All User Search parameter is set to False and no search criteria is set.
Searches are limited to 64 results and are random. If the directory contains more than 64 records, a message displays stating that the search exceeded the search limit and the user must specify more specific search criteria.
From this doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00803edad6.html#wp1025561
Hope this helps!
Rob
Thanks Rob this helps a lot.
