DTMF configration on Cisco IP PH 7965
jahanzaib.pgis
DTMF is configured on my gateway router but still i can not call on Extension when i call to my vendor Land Line. How we can enable on
IP PH in Call Manager 7.X.
7 Replies 7
kusatija
Do let us know the following:
exact call manager version.
is the issue only for 7965 phones?
is it an intermittent issue or reproducible?
whats the call flow, what is the gateway config from which the call is going out, is it MGCP/h323/SIP?
If MGCP post the running config, as well as screen shot of the gateway config.
If its an h323/SIP, post the running config and ccapi inout for a bad call.
DTMF is configured at the gateway, and is not configured for specific phones.
Kunal
thanks for your suppport!
1. call Manager version 7.x (7.1.5.10000-12).
2. this is SIP Gateway following is the SIP ( DTMF is configured on my Gateway router 2921)
Protocol= SIP
SIP Port = 5060
Transport Protocol=UDP
Voice Codec= G711 A-Law
DTMF = IN-Band DTMF without RFC2833
Signaling IP address = 10.205.20.50
3. I think this is Cisco IP PH setting in Cisco because before it was not working on Linksys SPA 942, 922  but i configured IN-Band in SPA 942,922 and now DTMF is enable and i can Dial landline extensions.
Good Luck,
Cool, so lets grab the following debugs from the gateway when you call from the 7965
debug voice ccapi inouit
debug ccsip messages
with the calling/called party numbers
Lets see what dial-peer we are hitting.
Also post the running config from the gateway, so we can see whats configured in the dial-peer.
Once i have this information i can suggest further.
Cheers!
Kunal
router #debug voice ccapi inout
voip ccapi inout debugging is on
Router#debug ccsip messages
SIP Call messages tracing is enabled
i applied these command and above result only.
check attachement!
is there any option in Call manager for DTMF enable ?
Hello!
If you are sure the call was going through the router, then most likely logging was enabled on the router, so u could have done a show log.
If the call is going through the SIP trunk on the call manager, on the SIP trunk config check the parameter:
You could try to set this to RFC2833, which force the call manager to send in band DTMF.
I am assuming that the other end is expecting DTMF inband.
Also i am assuming you are hitting dial-peer 100:
dial-peer voice 100 voip
description
translation-profile outgoing OutCalls
destination-pattern 9.T
session protocol sipv2
session target ipv4:10.205.20.50:5060
incoming called-number 9.T
voice-class sip dtmf-relay force rtp-nte
dtmf-relay rtp-nte digit-drop h245-signal
codec g711alaw
fax-relay ecm disable
fax-relay sg3-to-g3
fax rate disable
fax protocol pass-through g711alaw
no vad
The above is worth a try and might work, but with out the debugs its hard to say, so if the above does not work, do post the debugs requested.
Kunal
how we can set to RFC 2833? yes this is correct that other end is expecting DTMF Inband. i set DTMF INBAND in Linksys IP Ph and then SPA start
working for DTMF.
How we can set RFC2833? see attached log file.
hello,
So the gateway through which the call is going, is it added as a gateway or a trunk(sip) on the call manager?
Please confirm the same, if its a SIP trunk on the call manager, then try and change the following parameter:
DTMF Signaling Method to  RFC2833, see if this resolves the issue.
As then the DTMF will be sent in band, which the other end is expecting.
From the debugs, i realy can not reach a conclusion, we need more information, if the above does not resolve the issue, i suggest you to open a TAC case, so that we can have a look and do some deeper analysis, and troubleshooting.
Cheers!
Kunal
