Dynamic Hunt Group Membership - Key not active here
Mark Rigby
Greetings, im trying to configure dynamic hunt group membership for a small telesales team, however when trying to configure CME using the HLog "Agent Status Control" method i am unable to get the Softkey to activate on the IP Phone. ie "Key is not active here"
Looking at the CME admin guide it does mention having to assign wildcards the the hunt group but it was my understanding that this was only required when following the "Dynamic Membership" feature, this configuration has been taken from page 718/719 on the latest admin guide.
Has anyone got this working succesfully using this method if so is there something im missing? I can configure this feature using wildcards and the ephone-hunt login command under the DN but i would prefer i could just use the Hlog key for simplicity sake.
CME Version 7.1
Here's my current telephony service configuration:
(I have tried using both fac standard and fac custom)
telephony-service
hunt-group logout HLog
fac custom ephone-hunt hlog #21
fac custom trnsfvm #22
Hunt Group configuration:
ephone-hunt 3 peer
pilot 2001
list 8367, 8369, 8368, 8378, 8375, 8158, 8345
final 2000
timeout 15, 15, 15
no-reg pilot
description Telesales Department
display-logout Logged Out
Ephone Configuration
ephone  4
video
mac-address 001E.BE90.7978
ephone-template 3
type 7940
button  1:4
Ephone Template
ephone-template  3
softkeys idle  Newcall Redial Cfwdall Gpickup Pickup HLog
softkeys seized  Redial Pickup Gpickup HLog
softkeys alerting  Endcall
softkeys connected  Hold Confrn Trnsfer TrnsfVM LiveRcd Endcall HLog
softkeys ringing  Answer
features blocked  Park
18 Replies 18
Thank you very much, went to load 8.0(10) then 8.1(2) all is working fine now.
David Lin
Having the same problem on CME 10.0 + firmware 9-3-1.
Under telephony-service, I have following two lines,
 fac standard
then in ephone-dn, added ephone-hunt login
The HLog key is grey-out. dialed by *3 didn't work either. Same config on CME8.8+F/W 9-2-3 works fine.
Took out the hunt-group logout HLog under telephony-service, the key appeared as normal but didn't do anything when pressed on it.
Not sure this is firmware issue? But the new phone has to use 9-3-1 or above.
David,
Did you ever figure this out?  Running into the same issue...
Open new thread is better than replying a thread has 5 years old
Anas
