E&M card status - UP UP
cm6043
Hi ,
I cannot confrim whether the e&m card are hardware faulty. The users cannot make outgoing call and recieve incoming call.
                                  IN      OUT
PORT   CH SIG-TYPE   ADMIN OPER STATUS   STATUS   EC
1/0/0  -- e&m-imd    up    up   idle     idle     y
1/0/1  -- e&m-imd    up    up   idle     idle     y
1/1/0  -- e&m-imd    up    up   idle     idle     y
1/1/1  -- e&m-imd    up    up   idle     idle     y
Leung Che Man
paolo bevilacqua
Probably just miswired or misconfigured, up indicates the card has seized the circuit.
If it was working before, reload the router.
I have contacted the local PABX engineer to check the e&m wiring and reloaded the router. The status return to normal as follows and we can make call between other sites.
                                  IN      OUT
1/0/0  -- e&m-imd    up    up   seized   idle     y
1/0/1  -- e&m-imd    up    dorm idle     idle     y
1/1/0  -- e&m-imd    up    dorm idle     idle     y
1/1/1  -- e&m-imd    up    dorm idle     idle     y
Leung Che Man
