easy dial-peer question
davieshuw
Hi. I have two dial peers conflicting by the looks of it. Dial-peer 53 works fine.
dial-peer voice 53 pots
description ** Outgoing national landline / mobiles **
destination-pattern 90..........
port 0/1/0
forward-digits 11
no sip-register
A colleague tried to call a customer in Ireland (now a national call) and obviously didnt connect becasue I didnt have an international dial peer. OK.. so I write Dial-peer 54...
dial-peer voice 54 pots
description ** Outbound International Call **
destination-pattern 900...........
port 0/1/0
forward-digits 13
no sip-register
Yes, you guessed it.. My international call to 9 00 00 00 00 00 000 meets my dial-peer 53 rather than hitting dial-peer 54.
Is it just because im not using preferences or is my rule just incorrect?
nomiel
Hi.
As I understand, second 0 only occurs during international call, so you can write in dial-peer 53 destination-pattern 90[1-9].........
17 Replies 17
nomiel
Hi.
hi cheers for the response.. I now have..
destination-pattern 90[1-9]...........
port 0/1/0
forward-digits 13
no sip-register
but still the same issue. The last 2 digits of my international number are being chopped off.
Not dial-peer 54, but 53 needs [1-9]!
AJAZ NAWAZ
Level 5
Level 5
hmm...
look at this:
<http://www.cisco.com/warp/public/788/AVVID/backup_cm.html>
Note: When you set the preference order, the lower the preference number, the higher the priority. The highest priority is given to the dial peer with preference order 0 and it is the default value. You can have a preference value between 0 to 10.
Further configuration procedures are:
1. Set up the dial peer that points to the primary Cisco CallManager server with a preference of 1.
Note: In this case, the preference command takes effect because the destination patterns under the two dial peers are the same (otherwise "longest match" overrides it).
I want to take a further look at this. Be right back.
Ajaz
Right. I now have:
preference 10
port 0/1/0
forward-digits 11
no sip-register
and
preference 1
port 0/1/0
forward-digits 13
no sip-register
It still must be meeting dial-peer 53 because it still chops off the remaining 2 digits
Read towards the end of my previous post!.
Longest match rule overrides dial-peer preference configuration.
Ajaz
Yes, it states that the preferences are overidden if the destination patterns are the same; mine are not
Correct so which one of the patterns provides for the best match?, or are we saying that just one of them matches the dialed destination or are we talking in terms of choice between the two?
Ajaz
You are dialing a total of 14digits. The first dial peer (53) has the longest match pattern for this. In fact it's the only match since the second dial-peer (54) only has 12digits so it will not match period!
hth,
Ajaz
90[1-9]........... is only 12 digits then? because one of the zeros isnt forwarded in an international call?
I make that 14digits but [1-9] means any number from 1-9. What is the number you are dialling?
Ajaz
00 353 45 43 54 70
That's 13digits. So neither 12 nor 14.
NOTE - forward-digits (after outbound dial peer match)
try this - 90[1-9]..........
Ajaz
here is another situation. here is variable length dial-peer and selected shortest dial-peer, if it hasn't $ sign at the end
(http://cisco.com/en/US/products/sw/iosswrel/ps5207/products_configuration_guide_chapter09186a008086f2e2.html - Variable length matching)
