How to Add "do not call list" in the Dialer
muzammelhaque
I want to add "do not call list" in the outbound dialer ver 7.0.
Can anybody help me.
Muzammel Haque
7 Replies 7
Ayodeji Okanlawon
What do you mean by this? Can you explain better
Please rate all useful posts
In the outbound dialer we have customer notification service (CNS). By this, dialer upload numbers for outbound dials but we want to configure that some specific number (that we will define) dialer will not dial by the "do-not-call" list.
How we can configure that outbound dialer will not dial some predifined customer number.
Guide me.
Muzammel haque
You can use COR (class of restriction) for this.
Look at this excellent doc...
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a008019d649.shtml
HTH, pls rate useful posts
Thanks for the reply. I am talking about IPCC Enterprise solution with outbound dialer. "Do-not-call" list configuration is available and I need more details.
by the outbound dialer "Import Rules" you can select "do-not-call"list. My question is, we have already outbound campaign like "CNSCAMAPIGN" and import type is "contact" how we can add "do-not-call" list with the same campaign.
Muzammel haque
Did you try the steps in this document?
http://www.cisco.com/en/US/products/sw/custcosw/ps524/products_tech_note09186a00802d97a1.shtml
The screen shot may vary little bit but the steps are same
Reg/OS
Thanks for your time. I have already configured do-not-call list & is working fine but thing is this list is applicable for all the Outbound Campaign. I Want to add this list for a specific campaign (consider we have 5 campaign for different purpose).
Have you any suggestion.
Thanks in advance.
Muzammel
Quite interesting, Just thinking whether we can make use of the SQL query option in query rule. If it allow us to use a DSN. If you have any SQL programmer around give it a try. I have not used it as before and I am not sure Query Rule supports ODBC query but we can give it a try.
Reg/OS
