11-12-2008 11:08 PM - edited 03-15-2019 02:31 PM
I need to add a subscriber to an existing cluster.There are 1 pub and 3 subs in the cluster.CCM version is 4.1.3.
Is there any steps to be followed while adding the subscriber.
Looking for your suggestions...
thanks in advance
siva
11-13-2008 02:14 AM
Hi Sivakumar,
Take a look at this post by Rob, it provides a document link to the install doc for adding a new subsriber to an existing cluster:-
Hope this helps.
Allan.
Pls rate helpful posts.
11-13-2008 02:31 AM
Also just one extra point, you will have to use the correct build disks for version 4 that are the same as the base version on the Publisher or it won't allow you to join the cluster. For example you won't be able to build with 4.0, then upgrade to 4.1(3).
The bit I'm unsure about is if you need to remove any SRs first, as I've had mixed results with this where sometimes I've had to do this, and sometimes not.
11-14-2008 05:27 AM
Thanks for your reply.I have gone through the doc but it talks about the outline sketch.I would like to know in-depth steps or step by step procedure to install a subscriber and add to the existing cluster (database subscription pushing to new subscriber).
looking for your suggestions
thanks in advance
siva
11-14-2008 05:36 AM
DB replication is created automatically when adding a server to a cluster.
if you need step by step guides look at the CUCM install guides.
Install and Upgrade Guides
http://www.cisco.com/en/US/products/sw/voicesw/ps556/prod_installation_guides_list.html
the information provided already has the steps to add a subscriber.
most of this is a wizard, just follow instructions
java
if this helps, please rate
11-21-2008 06:08 AM
Thanks for valuable info..
regards
siva
