inbound CLID manipulation on CME
srosenthal
Level 4
Level 4
Is there a way to manipulate the CLID of inbound calls such to place a 9 and 1 in front of number?
The reason for this is so that phone users could just select the DIAL button from the directory without having to EditDial first?
Thanx, Seth
Here are the commands you need.
voice translation-rule 1
rule 1 /^0/ /910/
rule 2 /^1/ /911/
rule 3 /^2/ /912/
rule 4 /^3/ /913/
rule 5 /^4/ /914/
rule 6 /^5/ /915/
rule 7 /^6/ /916/
rule 8 /^7/ /917/
rule 9 /^8/ /918/
rule 10 /^9/ /919/
voice translation-profile Prefix91
translate calling 1
voice-port 0/0/0:15
translation-profile incoming Prefix91
7 Replies 7
safety2008
Level 4
Level 4
Seth,
We have ccm with 3845 router, we do it via the router. I am not the router expert, just an fyi that it can be done that way so your users just hit dial from missed call log. i will let you know if i get command string.
Our CME is also running on a 3845. Any commands that you can forward my way would be greatly appreciated.
Seth
rule 1 /^0/ /910/
rule 2 /^1/ /911/
rule 3 /^2/ /912/
rule 4 /^3/ /913/
rule 5 /^4/ /914/
rule 6 /^5/ /915/
rule 7 /^6/ /916/
rule 8 /^7/ /917/
rule 9 /^8/ /918/
rule 10 /^9/ /919/
translate calling 1
voice-port 0/0/0:15
The above is not a good example. It can be done with a single rule:
rule 1 // /91/
Note, depending on where you are, you can distinguish so that local calls are stripped of area coded and prepended with 9 only, international calls with 9011, etc.
I think I understand what you are saying. The problem with stripping the local area code is that some numbers in our area code do require a 1 and area code to be dialed.
Seth
That is a reason more to be willing to do that, because chances are that when you dial 11 digits when 7 would suffice, you will be billed for LD.
That did it, thank you very much.
Seth
