Incoming call from the PSTN to fxo still ringing after the caller disconnect
ahmed_ellboudy
Dear All
I have an issue with the incoming calls on the fxo ports of Cisco 2811 mgcp VG ,that is registered on CUCM 7.1.3 ,the issue is if the PSTN callers disconnect the call before the called number catch the call,the (called number which is the attendant DN that configured under this port),called number  still ringing after the caller disconnect the call.
The voice gateway running this version:(c2800nm-adventerprisek9-mz.124-21.bin ) .
Any advice for this issue?
Ahmed Ellboudy
7 Replies 7
Hello
You can try qhit this commands:
voice-port 1/0/4
supervisory disconnect dualtone mid-call
timeouts call-disconnect 2
timeouts wait-release 2
Dear Ivan,
I tried these commands befor with no updates.
any new advice?
Thanks,'
Ahmed Ellboudy
The calls do not disconnect because the router never knows that the call has been disconnected.
Telco can send Disconnect Supercision either as battery-denial, battery-reversal or one of the methods highlghted in the document.
Try to configure cptone applicable to your local region and see if it makes any difference.
Actually, most telco in the world do not use any method beside sending tones.
Configuring cptone is rarely enough.
Disconnect tone must be configured explcitely with its frequencies and durations.
dksingh
This is a classic case of disconnect supervision issue
If you have connection plar configured on the FXO port,
try changing it to connection plar opx.
And find out from your telco what disconnect supervision
mechanism they are using to configure the router to
detect the same and return the port onhook.
OP is using MGCP, consequently "plar opx" cannot be used.
