Interface ETh0 is duplicate ip
When i try to install Subscriber in the cluster, i receive an error message which i attached in this email : interface eth0 is duplicate ip.
The address doesn't exist on the network. i try to install on UCS C210 M2 server with ESXi 4.1.
If you have some responses about this trouble feel free to help me.
5 Replies 5
Chris Deren
My expereince with seeing this is that it is pretty accurate, I suggest you look at your ARP tables on the network to find annother device with this IP.
Chris
or find a network device on this subnet with proxy arp enabled....
HTH. Barry
I check network but i haven't something bad. No duplicate ip address in the network. But i have the same error. Do you know if my vmware layer is correctly configure ? because it's on my interface eth0 i have the error so may be the problem come in this side.
Thanks for you return
Joseph
jerome.lopez
Hi Joseph
How you solved the issue . I am facing the same issue.
Kindly please reply
JAVIERGUA
Delete the adapter interface, then add a new one.
