Introducing Number to Name service for CME and CM
paolo bevilacqua
This is a TCL/IVR script that uses a file with a list of numbers and names to make so your caller's name is displayed on the phone when receiving a call from a number in the list.
The file must reside in flash. This is because the "file" command that I use in the script fails for tftp. There is also a version what works  via HTTP queries.
The file is accessed for reading on the first call only, so it should be possible to handle very large lists.
To reload a the file, do:
show call application sessions
and then
call application session stop id <ID-from-show>
Update. The script can now be acquired at ciscoscripts.com
25 Replies 25
Stoyan Stoitsev
Level 8
Level 8
I was just looking for something similar! Can you give us information about model of the router and the IOS version you have tested it with.
BR,
Stoyan
this is supposed to work on any platform where TCL/IVR 2.0 and up is supported.
I do use ISRs for testing.
Let me know how it works for you.
pf
I have still problems with consultative call transfer if I use your script. A (external) calls B B transfers to C (consultative). After pressing the transfer-button on phone B. Both calls are still on hold.
Could you already test that? Have you a solution?
Thanks.
Peter
Hi Peter,
I was in the believing that the service was not to interfere with call transfer. I'm away from my systems, it can be sometime before I can go back to that, but I will.
Thanks for letting me know!
sdekooter
Hello Paolo,
I greatly appriciate the effort you putted into this. Is there any change you will further develop the script to do http queries on the fly?
Also I mentioned that you created another version of the script, which handles the DNIS/ANI another way, but I can not find the threath in which you explain why you made this changes.
Again, thanks a lot for all the effort.
Steve
No I never developed the http queries for lack of real need now.
Not sure about another way of handling ani/dnis, ani drives the name search and dnis the outgoing dp where the call goes.
I do mean that I saw another version of this .tcl on your website. What are the differences?
http requests would be real cool
Ah, that was not supposed to be seen, it's a modification for a T1 CAS that presents ani/dnis in a peculiar format. So far, that's the only case I've seen.
If someone can write the http server side, I won't take much time for me to adapt the client.
Thanks for the appreciation!
As you might have noticed I am a big fan of your CME additions :-) so sorry for taking a look in your back garden.
HTTP server side off course could be very flexible. We only would have to make some agreements about the format. I would suggest an parameter in the script where you put can put the ani as a variable, like:
param http_ani_get http://server/anirequest.asp?getnamefor=$ani
Any suggestions for return format? Going VXML-style with addiotional info, or simple HTTP answer containing Unknown vs 'Name of Caller'.
BR
Yes that would be exactly the method. Query can also be basic64 authenticated.
I would think that for simplicity, just have a simple string in reply.
Are you considering tying the names database to MS AD ? That is probably what most people would like,
In any case if you can place the server on a reachable IP, I'll patch the client, quickly test, and release for the community.
I set up a quick test:
http://xml.proxsys.nl/lookup.asp?ani=$ani
Valid entries are;
12345
54321
03912
If other numbers are entered, you get a reply with the same number returned. If you need modications, just let me know.
Will code and confirm...
Ok, done and quickly tested:
http://pbevila.fastmail.fm/public/number2name-http.tcl
I would need the server to have authentication, the code is in the client but I'm too lazy to debug it now.
Hi Paolo,
The script seems to work fine. However, tranfering doesn't work anymore if the script is configured under an incoming dialpeer.
I noticed that you replied in another topic about tcl and transfering a call. What is the story about it? Why doesn't it work?
Best regards.
