IOS Version for WIC/VIC Card in Cisco 2801 Router
Arifuddinkhaja
Hii all,
Greetings!!!
I have a query
We are having a Cisco router 2801 with one Adsl card ,one T1/E1, & one VIC card with 2 FXO ports
WIC/VIC Slot 2:
        FXO Voice daughter card (2 port)
        WIC module not supported/disabled in this slot
        Hardware revision 1.1           Board revision J0
        Serial number     24283772      Part number    800-02495-01
        FRU Part Number   VIC-2FXO=
        Test history      0x0           RMA number     00-00-00
        Connector type    Wan Module
        EEPROM format version 1
        EEPROM contents (hex):
          0x20: 01 0D 01 01 01 72 8A 7C 50 09 BF 01 00 00 00 00
          0x30: 98 00 00 00 01 01 31 01 FF FF FF FF FF FF FF FF
My query is
1.Which IOS ver should i run in my router which supports VIC card ?
Am having a cisco 2801 router with 128MB/64MB mem
Currently am using IOS ver "c2801-spservicesk9-mz.124-3g.bin" but its not supporting my VIC card.
Awaiting ur prompt response.
Thankyou in advance for ur understanding and cooperation.
Brgds,
Arif.
2 Accepted Solutions
paolo bevilacqua
That old card is not support in 28xx routers, no matter IOS used.
You must use VIC2-xFXO card.
Aaron Harrison
1) First problem is that VIC-2FXO isn't supported on the 2800 platforms - you need a VIC2-2FXO.
2) Secondly, you will need DSPs on your 2800 motherboard - these woudl appear in your hardware list on the router as PVDM2-xx
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
6 Replies 6
paolo bevilacqua
Thanks alot for ur reply.It really helped me alot
Can u tell exactly which VIC card supports 2801 with128/64Mb mem?
Appreciate ur prompt reponse.
Aaron Harrison
Aaron
Thanks for ur reply.
can u plz tell me what r da exact o/p commands to check pvdm & dsp on router(ASAP)?
Thanks in advance.
Show diag
Post the output if you don't understand it, but it's quite clear - basically if you have PVDMs you will see parts like PVDM2-32 for example
The last number (32) indicates the number of DSP channels - for a 2 port VIC, you require at least 2 channels for G711 calls. If you are running G729 or other codecs you would need more. I think the smallest is a PVDM2-8.
Aaron
Thankyou soo much for ur reply.
Can u plz post a sample ASDL configs on 2801 router with one ATM interface(ASAP)
Awaiting ur quick response.
