09-06-2007 09:53 AM - edited 03-14-2019 11:24 PM
Guys,
I am having a bit of a trouble here, i am able to make out going calls for all the extensions, but on an inbound call from out side on any of the PRI numbers, i get a dial tone after dialing, after which if i dial the extension number, the extension rings other wise not can any one please help me out to resolve this issue i am also attaching the config file.
09-06-2007 10:02 AM
Your DP 1 is not matching the called number:
dial-peer voice 1 pots
incoming called-number 1..
Change to what you see in "debug isdn q931" and the call will accepted.
I don't know if you have DID and if so what "dialplan-pattern" is needed under telephony-service. That is also needed to ring the extensions directly from outside.
09-06-2007 10:11 AM
thanks for ur reply i had tried using 1.. in dial peer but it did not work
i also configured dialplan patter
the DID range is from 8020100 to 8020299
09-06-2007 10:36 AM
So configure incoming called-number 8020...
You can remove the port from the incoming DP, it is not used.
and "dialplan-pattern 1 8020... extension-length 3"
As an appreciation to those providing answers, please rate useful posts using the scrollbox below!
09-06-2007 11:03 PM
i tried the paramaters mentioned still the same.
09-06-2007 11:38 PM
Then just use .. for incoming called-number in the DP that has direct-inward-dial. Or take debugs isdn q931 with term mon and place the correct number.
09-06-2007 11:51 PM
ok i ll try this tomorrow and reply abt the result
09-07-2007 12:16 AM
put the cmd "direct-inward-dial" under your POTS dial peers this should stop the secondary dial tone, also how many digits is your service provider presenting BT present 6 by default so unless you have asked for only 3 to be presented you will need a translation pattern to change the incoming 6 digits to 3.
I hope this helps
09-07-2007 05:17 AM
Dear Anderson
the number provided by the telco is 8020222 the range i have been given is 8020100 to 299.i hav configrued the extensions starting from 100 to 135 i have arleady put direct-inward-dial. can u tell me how to do the translation.
Cheers
aamir
09-07-2007 05:36 AM
The command under telephony-service is:
dialplan-pattern 1 8020... extension-len 3
This assumes telco is sending 7 digits for called number thing that you can verify with "term mon" and "debug isdn q931".
09-07-2007 11:37 PM
Dear the following is the result of debug isdn q931
Sending Complete
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98388
Exclusive, Channel 8
Progress Ind i = 0x8483 - Origination address is non-ISDN
Calling Party Number i = 0x2183, '048850447'
Plan:ISDN, Type:National
Called Party Number i = 0x81, '0122'
Plan:ISDN, Type:Unknown
Sep 8 07:20:15.386: ISDN Se0/0/1:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x9
D52
Sep 8 07:20:15.386: ISDN Se0/0/1:15 Q931: TX -> CONNECT pd = 8 callref = 0x9D5
Sep 8 07:20:15.846: ISDN Se0/0/1:15 Q931: RX <- CONNECT_ACK pd = 8 callref = 0
x1D52
Sep 8 07:20:15.846: ISDN Se0/0/1:15 **ERROR**: call_progress: DEV_CONNECTED VOI
CE ERROR: Bearer capability not available(0x3A): b channel 7 call id 0xF8
can u please go throug and help me
09-08-2007 01:50 AM
Telco is passing four digits. Use
"incoming called-number 0..." and
"dialplan-pattern 1 0... extension-length 3".
09-09-2007 08:18 AM
thanks my issue is resloved and i have rated ur post
09-09-2007 08:30 AM
Thanks for the nice rating and good luck!
