11-11-2009 07:51 AM - edited 03-15-2019 08:28 PM
I know that this can sound weird, but the question is.
I have to create a h.323 trunk between two CCM.
Is it possible to use the same route pattern ex : 6xxx on both side of the trunk ( exemple if there is 6xxx extension on both system.
Solved! Go to Solution.
11-11-2009 07:53 AM
Yes, just make sure the inbound CSS from the ICT doesn't reach the 6XXXX partition, otherwise it would loop.
The ICT should only be able to reach the DNs you want via CSS and partitions
java
if this helps, please rate
11-11-2009 07:53 AM
java
11-11-2009 08:11 AM
thanks a lot
