Join two conefrences
j.huizinga
Level 6
Level 6
Assume the following:
A manager initiates a conference with two other persons. Then he tells his secretary to add two other person to the existing conference.
Is this possible?
I tried to transfer a conference to the manager's phone and then let the manager join this conference with the existing conference on his phone, but this doesn't seem to work.
JH
5 Replies 5
Jaime Valencia
CME??? CUCM??? Version???
ALWAYS mention what you have to work with, and not only what you want to do
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Sorry, you are right.
CUCM version 6.1.3
JH
Ad Hoc Conference Linking
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/6_1_1/ccmsys/a05confb.html#wp1061274
java
java
I have read this and I understand this.
But I have the following problem:
Manager makes from his phone a conference with two people.
Assistant makes a conference with two other people, and she wants to forward this conference to the manager.
So now the manager has two conferences on his phone. The manager must be able to join these two conferences into one conference and the Assistant should be able to hang up and not destroy 'her' conference.
I can not make this work. Am I trying something that is impossible?
thanks,
Jan
No, you just need to read a little more, because apparently you skipped some parts from the link.
•Drop Ad Hoc Conference
The parameter you need to link the conferences is after the above one, and the above one explains how a conference should behave ie if the initiator drops.
java
java
