MOH Disappeared
peternnaji
I have CCM4.1 and since it does not support CP-7911 by default, I uploaded the firmware and device park for CP-7911 onto the CMM to be able to use the Phone model. After successful upload, I noticed that my MOH no longer plays, intsead it gives an intermitent beep sound every 3 - 4 secs. Is there any way I can restore my MOH?
It's the IP Voice Media Streaming, it's the service in charge of the MOH server, you can do it from the serviceability. restart it in all the servers where the service is running.
javalenc
if this helps, please rate
java
5 Replies 5
Jaime Valencia
try restarting the IPVMS, make sure the MOH files are in there and also that the phones have a MRGL which has a MOH server in it
javalenc
java
Hi javalenc,
The MOH are there and the phones have a MRGL. What's IPVMS and how do I go about restarting it?
Hi javalenc,
javalenc
java
Thanks a lot. It works fine now.
