MOH on CUCM 6.0 not working
shikamarunara
Level 4
Level 4
My default MOH seems to be working fine, but when I upload new audio sources and set them on either a device or one of its lines, I get dead air. Has anyone else run into this?
-Shikamaru
MAke sure you upload the files to each MOH server or each CCM Server in which MOH server is enabled
6 Replies 6
gogasca
Level 10
Level 10
Which file are you using?
Which format?
Can you post it or send it to my email?
gogasca cisco com
gogasca,
I have been using the .wav files from the CUCM 6.0 MOH disc.
-Shikamaru
gogasca
Level 10
Level 10
Shikamaru
Are you using multicast for those resources...and which codec you are using, r u getting dead air or tone on hold?
Any device that may be blocking the audio?
If u can upload the trace i will be more than glad to help you
We are using G.711. No tone on hold, only dead air. Audio is not being blocked because the sample MOH plays fine.
-Shikamaru
I have similar problem. Can someone clarify how to upload MoH file on each separate server?
I have three CUCM MOH servers in the cluster. I upload the file via CUCM Administraion GUI->Media Resources->MOH audio file management. My understanding is that the file should be replicated to all configured MOH servers in the cluster.
But it seems it isn't. I found this log restarting IP VOice Media Streaming Application service:
12/16/2009 12:19:43.503 VoiceStrm|   CIpVMSMgr::GetAFile *ERROR* Error getting MOH source file, errno=2|<:CUCM><:10.131.3.138><:ERROR><:0002>
12/16/2009 12:19:43.504 VoiceStrm|kMOHTFTPGoRequestFailed - Start of download request failure. File Name: App ID:Cisco IP Voice Media Streaming App Cluster ID:CUCM Node ID:kol01-cm02|<:CUCM><:10.131.3.138>
<:ALARM><:ALL><:FFFF>
I can see server cannot open audio file when it tries to play audio:
12/16/2009 11:37:01.310 VoiceStrm|   CIpPlayWav::StartPlaying (78,2003,0) *ERROR* Error openning WAV file (/usr/local/cm/moh/TestMoH.g729.wav)|<:CUCM><:10.131.3.138><:ALL><:0002>
12/16/2009 11:37:01.310 VoiceStrm|-->CIpPlayWav::ErrorCleanup (78,2003,0) |<:CUCM><:10.131.3.138><:ALL><:0002>
12/16/2009 11:37:01.310 VoiceStrm|<--CIpPlayWav::ErrorCleanup (78,2003,0) |<:CUCM><:10.131.3.138><:ALL><:0002>
12/16/2009 11:37:01.311 VoiceStrm|   CMOHMgr::PlayStream (78,2003,0) /usr/local/cm/moh/TestMoH.g729.wav failed to start|<:CUCM><:10.131.3.138><:ERROR><:0400>
My System version: 6.1.2.1000-13
