No MoH on UCM 6.1(2)
We moved from Callmanager 4.2(3) to UCM 6.1(2). DMA seemed to migrate all the data, but it appears Music on Hold is not working. I'm guessing this should be simple, but I can't seem to find the source of the problem. Music source exists, MoH server is running, and Media streaming service is running. Any ideas?
Thanks in advance.
Chris Deren
Did you have custom MOH files? These do not get migrated via DMA, make sure you re-upload these.
Chris
6 Replies 6
Chris Deren
Chris
Bingo ... thanks!
Brian
Great!
thisisshanky
Level 11
Level 11
Also make sure you upload the files individually to all the MOH servers in the clusters...These files are not sync'd
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
This post was exactly what i was looking for.
I have been searching online for a while about this issue. Thanks guys!!!!
Cool, make sure you rate the post so it's easier for others to find in the future.
Chris
