07-30-2014 02:07 AM - edited 03-16-2019 11:33 PM
Dear all,
We have 2 CallManagers at our organization. Incoming calls are routed to Attendant Console to listening Music on Hold. Whenever the Publisher CallManager is down, calls coming into our organization receive a busy signal. I thought we were setup for redundancy, but I found out the hard way that this was not the case.
We have a 2911 router which routes incoming phone traffic into our organization. On it are two dial peers which route our organization?s incoming calls to the CallManagers. The primary dial peer is supposed to route to the publishe and the secondary dial peer to the subscriber. Below are the 2 dial peers which route our traffic.
voice class h323 1
h225 timeout tcp establish 3
dial-peer voice 11 voip
preference 2
destination-pattern 3.......
session target ipv4:10.1.11.30 ( publiser)
dtmf-relay h245-alphanumeric
codec g711alaw
dial-peer voice 10 voip
preference 1
session target ipv4:10.1.11.31 ( subcriber)
codec g711alaw
If i delete dial peer voice 11, incoming call can route to subcriber successfully
I would appreciate anyone taking the time to look at them and offer any suggestions.
CCM 10.0
I got debug for this as below:
TSI-DC-VGR01-0#end
Translating "end"
% Bad IP address or host name
Translating "end"
% Unknown command or computer name, or unable to find computer address
TSI-DC-VGR01-0#
Jul 30 07:48:09.066: //-1/AEEEB6D6813B/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=
----- ccCallInfo IE subfields -----
cisco-ani=0905916072
cisco-anitype=2
cisco-aniplan=1
cisco-anipi=0
cisco-anisi=3
dest=38236688
cisco-desttype=0
cisco-destplan=1
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
Jul 30 07:48:09.066: //-1/AEEEB6D6813B/CCAPI/cc_api_call_setup_ind_common: Interface=0x2BA17414, Call Info( Calling Number=0905916072,(Calling Name=)(TON=National, NPI=ISDN, Screenin
etwork, Presentation=Allowed),
Called Number=38236688(TON=Unknown, NPI=ISDN),
Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinatioag=TRUE,
Incoming Dial-peer=9, Progress Indication=NULL(0), Calling IE Present=TRUE
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=F
E), Call Id=-1
Jul 30 07:48:09.066: //-1/AEEEB6D6813B/CCAPI/ccCheckClipClir:
In: Calling Number=0905916072(TON=National, NPI=ISDN, Screening=Network, P
entation=Allowed)
Jul 30 07:48:09.070: //-1/AEEEB6D6813B/CCAPI/ccCheckClipClir:
Out: Calling Number=0905916072(TON=National, NPI=ISDN, Screening=Network,
sentation=Allowed)
Jul 30 07:48:09.070: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jul 30 07:48:09.070: :cc_get_feature_vsa malloc success
Jul 30 07:48:09.070: cc_get_feature_vsa count is 1
Jul 30 07:48:09.070: :FEATURE_VSA attributes are: feature_name:0,feature_time
0612504,feature_id:1877
Jul 30 07:48:09.070: //1877/AEEEB6D6813B/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=0905916072(TON=National, NPI=ISDN, Screening=Netw
Called Number=38236688(TON=Unknown, NPI=ISDN))
Jul 30 07:48:09.070: //1877/AEEEB6D6813B/CCAPI/cc_process_call_setup_ind:
Event=0x2B9DF948
Jul 30 07:48:09.070: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 38236688
Jul 30 07:48:09.070: //1877/AEEEB6D6813B/CCAPI/ccCallSetContext:
Context=0x300C4B5C
>>>>CCAPI handed cid 1877 with tag 9 to app "_ManagedAppProcess_Default"
Jul 30 07:48:09.070: //1877/AEEEB6D6813B/CCAPI/ccCallProceeding:
Jul 30 07:48:09.070: //1877/AEEEB6D6813B/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=TRUE, Mode=0,
Outgoing Dial-peer=10, Params=0x300C606C, Progress Indication=NULL(0)
Jul 30 07:48:09.070: //1877/AEEEB6D6813B/CCAPI/ccCheckClipClir:
entation=Allowed)
sentation=Allowed)
Destination Pattern=3......., Called Number=38236688, Digit Strip=FALSE
Calling Number=0905916072(TON=National, NPI=ISDN, Screening=Network, Prese
tion=Allowed),
Redirect Number=, Display Info=
Account Number=, Final Destination Flag=TRUE,
Guid=AEEEB6D6-16F4-11E4-813B-A4934C055B80, Outgoing Dial-peer=10
Jul 30 07:48:09.070: //1877/AEEEB6D6813B/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-username=
cisco-anitype=2
cisco-aniplan=1
cisco-anipi=0
cisco-anisi=3
dest=38236688
cisco-desttype=0
cisco-destplan=1
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
Jul 30 07:48:09.070: //1877/AEEEB6D6813B/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x312C8048, Interface Type=1, Destination=, Mode=0x0,
Call Params(Calling Number=0905916072,(Calling Name=)(TON=National, NPI=IS
Screening=Network, Presentation=Allowed),
Called Number=38236688(TON=Unknown, NPI=ISDN), Calling Translated=FALSE,
Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-
r=10, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, A
ication Call Id=)
Jul 30 07:48:09.074: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jul 30 07:48:09.074: cc_get_feature_vsa count is 2
Jul 30 07:48:09.074: :FEATURE_VSA attributes are: feature_name:0,feature_time
0612952,feature_id:1878
Jul 30 07:48:09.074: //1878/AEEEB6D6813B/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
Jul 30 07:48:09.074: //1878/AEEEB6D6813B/CCAPI/ccCallSetContext:
Context=0x300C601C
Jul 30 07:48:09.074: //1877/AEEEB6D6813B/CCAPI/ccSaveDialpeerTag:
Jul 30 07:48:19.386: //1877/AEEEB6D6813B/CCAPI/cc_api_call_disconnected:
Cause Value=102, Interface=0x2BA17414, Call Id=1877
Call Entry(Responsed=FALSE, Cause Value=102, Retry Count=0)
Jul 30 07:48:19.386: //1878/AEEEB6D6813B/CCAPI/ccCallDisconnect:
Cause Value=102, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconne
Cause=0)
Cause Value=102, Call Entry(Responsed=FALSE, Cause Value=102)
Jul 30 07:48:19.386: //1878/AEEEB6D6813B/CCAPI/cc_api_get_transfer_info:
Transfer Number Is Null
Jul 30 07:48:19.386: //1877/AEEEB6D6813B/CCAPI/ccCallDisconnect:
Cause=102)
Cause Value=102, Call Entry(Responsed=TRUE, Cause Value=102)
Jul 30 07:48:19.386: //1877/AEEEB6D6813B/CCAPI/cc_api_get_transfer_info:
Jul 30 07:48:19.386: //1878/AEEEB6D6813B/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x312C8048, Tag=0x0, Call Id=1878,
Call Entry(Disconnect Cause=102, Voice Class Cause Code=0, Retry Count=0)
Call Disconnect Event Sent
Jul 30 07:48:19.386: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jul 30 07:48:19.386: :cc_free_feature_vsa freeing 2C24DB50
Jul 30 07:48:19.386: vsacount in free is 1
Jul 30 07:48:19.394: //1877/AEEEB6D6813B/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x2BA17414, Tag=0x0, Call Id=1877,
Jul 30 07:48:19.398: //1877/AEEEB6D6813B/CCAPI/cc_api_call_disconnect_done:
Jul 30 07:48:19.398: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jul 30 07:48:19.398: :cc_free_feature_vsa freeing 2C24D990
Solved! Go to Solution.
07-30-2014 02:58 AM
can you try the below :-
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g729r8
voice class h323 1
h225 timeout setup 3
no codec g711alaw
voice-class codec 1
voice-class h323 1
no codec g711alaw
voice-class codec 1
voice-class h323 1
please rate all useful information
07-30-2014 03:12 AM
No, it is not for change codec , you can take a look i use g711 & g729 under voice-class codec ,but i share with him a success configuration for me to see if he can see h323 command , may be there is a bug or he has to upgrade the IOS , it is very strange that he is unable to see h323 under dial-peer. I agree with you 100% that he has to apply voice-class h323 1. I need to see may be my configuration can solve the issue.
thanks
07-30-2014 02:29 AM
This is most likely because you didnt apply your voice class h323 to the dial-peers..
voice-class h323 1
voice-class h323 1
This command basically tells the router to fail over to the next dial-peer in 3sec. without this, the default failover time for cisco dial-peers is 12sec. The problem with this is that the isdn timeout timer is 10sec, so before the call fails over to the second dial-peer, your provider would have terminated the call. So you need to apply this tom ake the fail over happen well below the 10sec time
07-30-2014 02:32 AM
Hi Okanlawon,
I did your command already but when we do show run, it doesn't appear.
Problem still exist.
ThanhNT
07-30-2014 02:57 AM
What is the IOS version on your gateway. I have never seen a case where the voice class command doesnt show in your dial-peer. That doesnt look right.
07-30-2014 02:58 AM
voice class codec 1
voice class h323 1
no codec g711alaw
voice-class codec 1
voice-class h323 1
no codec g711alaw
voice-class codec 1
voice-class h323 1
07-30-2014 02:58 AM
Islam,
Why are we asking him to change the voice class codec? Is this related to the problem at hand?
07-30-2014 03:12 AM
thanks
07-30-2014 03:31 AM
Dear Okanlawon & islam.kamal,
Both of you are correct. I used your command and it worked now. It also help me solved the problem related to Music On Hold cause i use g711ulaw ( MoH wont work with incoming call).
I used c2900-universalk9-mz.SPA.151-4.M4.bin
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.1(4)M4,
EASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Tue 20-Mar-12 18:57 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M15, RELEASE SOFTWARE (fc1)
Thank you very much ! You are the god !
ThanhNT
07-30-2014 03:38 AM
Well,
Looks like only Islam's answer was marked as correct!
07-30-2014 04:27 AM
+5 for your Ayodeji ,you are the owner of the solution of course .
07-30-2014 04:33 AM
I just find correct button on your side but no lucky. Maybe forum only give one times to click
