04-10-2007 05:03 PM - edited 03-14-2019 08:55 PM
We have a Plantronics H261 headset to be use in our 7941g cisco phone. But it has a buzzing sound whenever we use it and everything is fine when the handset is use. Is the headset not compatible to 7941g phone?
anyone can help?
tnx,
robert
04-10-2007 05:07 PM
a. Try the headset that has this problem on multiple cisco phones. Does it work on other phones ? Or does it behave the same on all phones ?
b. Does trying a diff. H261 headset help ?
04-10-2007 05:24 PM
thanks for a fast reply.
a. it works perfectly on Nortel Phones. All of our H261N have the same behaviour on our 7941g phones (only model we have).-it has a buzzing sound only on one side.
b. actually our headset are all new and we don't have any...
thanks
04-10-2007 06:17 PM
Look at this link.
There definitely seem to be two versions of this headset one compatible with Nortel and other with Cisco.
Sankar
PS: please remember to rate posts!
04-10-2007 06:49 PM
We've used the H261Ns on 7940's, 7960's and 7970's with no problem. We don't have any 41's, 61's or 71's though to try them on.
04-10-2007 07:40 PM
I see now the problem, our headset is for Nortel, no wonder it works fine w/ Nortel!
Now I got another headset here, CN Netcom 2000, can anyone show me the link or tell me that its not compatible w/ 7941 ip phones?
thanks
04-11-2007 05:00 AM
Hi Robert,
If you look at the link the Sankar sent (nice one!) you will notice the only difference is in the type of cord that is used. If you order the (26716-01) for about US$12 you will be good to go :)
For Nortel phones;
Plantronics Polaris Direct Connect Quick Disconnect to Modular Plug 10-Foot Coiled Cable (27190-01)
For Cisco phones;
Plantronics Quick Disconnect to Modular Plug 10-Foot Coiled Cable (26716-01)
Hope this helps!
Rob
