PLAR sendind calling number
Hello, im quite new to voip world, so i have a rewarding and challenging
Job, there is my question.
I manage a little network, we have a few PSTN lines to our GW, some of these lines are "fowarded" to IP extensions within the network using PLAR but i cant get the caller number to be displayed in the ip phone
Any suggestions?
Thanks in advance
Cesar
gogasca
Level 10
Level 10
Hola Cesar,
First question is if you connect an analog phone do you recieve Caller ID from Telco?
Then enable caller id in voice ports by using caller-id enable command
http://www.cisco.com/en/US/docs/ios/12_3t/voice/command/reference/vrht_c4.html#wp1059594
Then you can post your config and run some debugs:
debug voice ccapi ino
debug vpm signal
Ok, I was supposing that i was receiving the information from telco but it was not right, thanks a lot for your help.
Cesar
