Problem in outgoing calls
dbenattou
hello
i have call manager that is connected to PBX via BRI of 2811 gateway, the problem is when some calls between Cisco IP phone and the phone that is behind PBX does not pass, and it dipslays an error message.In attachment you will find trace of the debug isdn q931.
bwilmoth
Level 5
Level 5
isdn map address .* plan isdn type unknown You can use plan as unknown or international.Actually telco should tell you what the plan type should beOther options available for the plan and type are:
router(config-if)#isdn map address .* ?
plan Set address numbering plan
router(config-if)#isdn map address .* plan ?
data Data plan
isdn ISDN plan
national National plan
privacy Private plan
reserved Reserved extension
reserved/10 Reserved value 10
reserved/11 Reserved value 11
reserved/12 Reserved value 12
reserved/13 Reserved value 13
reserved/14 Reserved value 14
reserved/2 Reserved
reserved/5 Reserved value 5
reserved/6 Reserved value 6
reserved/7 Reserved value 7
telex TELEX plan
unknown Unknown plan
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a0080444966.html#wp1025089
router(config-if)#isdn map address .* plan isdn ?
type Set address number type
router(config-if)#isdn map address .* plan isdn type ?
abbreviated Abbreviated type
international International type
national National type
network Network type
reserved Reserved type
subscriber Subscriber type
unknown Unknown type
