CCM_CALLMANAGER-CALLMANAGER-3-CallManagerFailure : Indicates some failure in the Cisco CallManager system. Additional Text [Optional] [String] Host name of hosting node. [String] IP address of hosting node. [String] Reason code. [Enum]
Explanation - This alarm indicates that some failure occurred in the Cisco CallManager system.
Recommended Action - Monitor for other alarms and restart Cisco CallManager service, if necessary.
Reason Code - Enum Definitions
Enum Definitions - Reason
Value Definition
1 Unknown
2 HeartBeatStopped
3 RouterThreadDied
4 TimerThreadDied
5 CriticalThreadDied
6 DeviceMgrInitFailed
7 DigitAnalysisInitFailed
8 CallControlInitFailed
9 LinkMgrInitFailed
10 DBMgrInitFailed
11 MsgTranslatorInitFailed
12 SuppServiceInitFailed
The below URL explains about how to enable a Media Gateway Control Protocol (MGCP) gateway to fallback to an H323 session application when the WAN Transmission Control Protocol (TCP) connection to the primary Cisco CallManager server is lost, and no backup Cisco CallManager server is available.
