03-15-2007 09:04 AM - edited 03-14-2019 08:30 PM
I have configured IP phone encryption phone-to-phone. Now I would like to configure encryption phone to h323 gateways so incoming and outgoing calls are encrypted to/from the gateways. Does anyone have a link or any information about this?
Chris
Solved! Go to Solution.
03-15-2007 03:56 PM
Chris, I didnt mean to say that.
H323 encryption is supported in 4.1,4.2, 5.x etc. You have to have a min. IOS version to support SRTP command under dial-peers.
http://www.cisco.com/en/US/products/ps6441/products_feature_guide09186a008068b526.html
03-15-2007 09:23 AM
Yes, its very simple. Enable encryption under the dial peers, using command
"srtp".
If using a MGCP gateway, you have to configure a few commands for MGCP to enable signalling encryption. To setup media encryption for RTP you will have to build a ipsec tunnel to callmanager (pub and sub's).
http://www.cisco.com/en/US/products/ps6441/products_feature_guide09186a008068b526.html#wp1123262
HTh
Sankar
PS: please remember to rate posts!
03-15-2007 09:25 AM
Do you know how RTP encryption works with IPCC?
Chris
03-15-2007 09:32 AM
Chris,
CM 4.1 doesnt support encryption on CTI devices. It seems CM 5.x has support for encryption on CTI devices, but i have never setup encryption to IPCC.
03-15-2007 11:06 AM
So this would mean any RTP traffic from IPCC wouldn't be encrypted?
Also, do you know if this is the case in CM 4.2?
Chris
03-15-2007 11:08 AM
Looks like its not supported in 4.2 as well.
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/4_2/sec_vir/ae/sec423/secuview.htm
Hopefully this is roadmapped for 4.x train in future.
03-15-2007 12:08 PM
So the H323 encryption is only supported in CM5.0 and above?????
Chris
03-15-2007 03:56 PM
03-16-2007 08:43 AM
I would discourage srtp/encryption, too many things won't work or have caveats. Give it some time to work out the issues.
03-16-2007 08:53 AM
Can you tell me some of the things that don't work or have caveats?
Chris
