06-25-2012 01:21 PM - edited 03-16-2019 11:50 AM
I have a SIP trunk from a TSP terminated on the CUBE. - c2901 gateway connected via H323 to a CUCM 8.5 cluster. The signalling looks OK but I have no voice. The provider seems to support only G.729br8 codec and my phones (c6901 and c6921) seem to talk G.729r8 only so I need to do some transcoding. I'm in the UK btw.Now, I can do it on the CUBE and utilize dspfarm but that is I think only possible with SCCP. How do I register the gateway in CUCM, if it's already there as the H323 gateway?
Is there any way to do the transcoding on the CUCM? Any general advise would be much appreciated.
Cheers
Solved! Go to Solution.
06-28-2012 04:09 AM
Great stuff - that did it.
Thanks a lot for your excellent advice and spending your time on this.
The only remaining thing I'm having with this SIP trunk is that the translation profile doesn't seem to work as I want to.
The profile on the CUBE
voice translation-profile SIP-TRUNK-IN
translate calling 200
translate called 100
with the rule (I've tested it with "test voice translation-rule")
voice translation-rule 100
rule 1 /^01387345\([8-9]..\)$/ /5\1/
is assigned to
dial-peer voice 1 voip
description *** INBOUND SIP TRUNK PEER ***
translation-profile incoming SIP-TRUNK-IN
but it won't do the translation from 013873458XX to 58XX. The CUCM dial peers are then not matched for 5[8-9]..
I can go round this because I can manipulate the format of the called number coming from the ITSP (I can change it on a web portal from 013873458XX to 58XX) but it's not nice. And it puzzles me why the translation profile won't apply.
Pavel
06-28-2012 04:39 AM
I am happy that fixed it. Its always a good idea to mark the post as correct asnwer so it will help others to see that a suggestion fixed it. So feel free to mark the post that fixed the issue as correct answer
Please rate useful posts
"For the love of God is broader than the measure of man's mind And the heart of the Eternal is most wonderfully kind"
06-28-2012 04:20 AM
The reason why this is not working is because the called number is not 5811 from the sip provider..
Your dial-peer 1 is like this..
incoming called-number 5[8-9].. (this is not the incoming called number)
it should be this..
incoming called-number 01387345[8-9]..
Then when this dial-peer is matched, the xlation will be applied.
09-21-2012 03:57 AM
Hi pjiracek,
Well done. Im in the UK too and would like to test mine. Could you tell me who's your SIP provider please. Thanks
Jeff
09-21-2012 04:05 AM
Hi Jeff,
We use Thus (C&W) as our SIP trunk provider. They are also our WAN provider.
Cheers
Pavel
