09-23-2009 04:27 PM - edited 03-18-2019 10:36 AM
Guys,
trying to add a third subscriber to my 6.1.2 system and for whatever reason i couldnt remember the security password or at least i thought so since it was telling me vaildation failed. so i went ahead and tried to reset the password via the CLI using
set password security (press enter)
enter old password (i pressed enter)
enter new password (entered new password)
confirm new password (enter new password again)
and im getting the following error - This is my primary
Executed command unsuccessfully
/usr/local/bin/base_scripts/InstallWizard: option requires an argument -- p
any immediate assistance would be more than greatly appreciated
Solved! Go to Solution.
09-24-2009 12:02 AM
I am not sure about the error however you can try reseting the password using the link given below.
you need physical access to CUCM
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/6_1_3/cucm-rel_note-613a.html#wp544257
Cisco Unified CM does not support recovery of administration or security passwords. If you lose these passwords, you must reset the passwords, as described in the Cisco Unified Communications Operating System Administration Guide.
Other experts can confirm
~Neeraj
09-24-2009 12:02 AM
~Neeraj
09-24-2009 04:02 AM
just tried it on our lab system (vmware) and i got the same error initially. with the command reset password security , i need to still know my old password (i know it is kind of obvious).
the document you sent seems to be what im looking for.
the media it is asking for when i use pwrecovery is the CUCM installation media correct?
09-24-2009 04:09 AM
even blank cd should work ...as it only checks for physical access to system
09-24-2009 04:20 AM
Thanks once again for the speedy reply, the drama because of lack of documentation :)
so just for everyone that doesnt have it all up there when reading the procedure like i did.
1. the command "set password security" - does NOT work if you DONT know your initial password
2. get physical access to the system, log in using pwrecovery and password pwreset
3. have a CD in hand (any CD that you have on hand) and follow the on screen instructions.
4. Do this for ALL systems you have in the cluster
Just did it and it works :)
09-24-2009 04:21 AM
geez,
to think i opened a TAC for this :)
also, if youre thinking you can use putty or something like that and have someone onsite to just put in and remove the CD you would not be able to get through. you need to be there.
