Subscriber Unable to connect with Publisher
Hi guys.
Somebody already get this error on installing Subcriber?
CUCM 7.1.3a
The publisher name is correct
The security password is correct
Don't have DNS
Have licenses to 2 nodes
I already tried cable between the servers
Peterson
13 Replies 13
allan.thomas
Level 8
Level 8
Could please kindly elaborate on what you mean by the fact that the Subscriber is unable to connect with the Publisher?
Ordinarily when you build the subcriber, part of the process ensures that the subscriber has reachablility with the Publisher otherwise the installation would fail.
Allan.
David Hailey
Please post the exact error you are getting.
If this is during installation, the likely error is related to NTP status on the Publisher.  If the Publisher is not sync'd to a valid NTP source, then then Subscriber will not be able to sync with the hardware clock on the Pub.
However, without knowing the exact error - no one on the forums can be of much help.
Hailey
On Publisher
Services are running
On System -> Server, added Subscriber ip address
Put DVD on Subscriber and install.
This server is publisher node? No
hostname pub: xxxx
ip address: xxxx
security pass: xxxx
confirm secur pass: xxxx
click ok
Ntp syncronizing.... OK
show error
Unable connect if publisher
confirm the name ccmpub
confirm the ip address
confirm the security pass
the ccmpub is with correct ip address?
ccmpub is powered?
This is errors
Ok, that's what I thought. The subscriber cannot sync it's hardware clock with the Publisher. Are you using NTP for time source on the Publisher? If so, go to the command line and type "utils ntp status" and post the output.
Hailey
Please rate helpful posts!
admin:show ntp status
Executed command unsuccessfully
No valid command entered
admin:util
admin:utils ntp status
ntpd (pid 29404) is running...
     remote           refid      st t when poll reach   delay   offset  jitter
*127.127.1.0     LOCAL(0)        10 l   47   64  377    0.000    0.000   0.002
synchronised to local net at stratum 11
   time correct to within 12 ms
   polling server every 1024 s
Current time in UTC is : Wed Apr 21 19:59:58 UTC 2010
Current time in America/Sao_Paulo is : Wed Apr 21 16:59:58 BRT 2010
admin:
So, you are not using NTP - instead, you are using the local hardware clock on the Publisher. NTP is recommended; however, I believe it must be added during installation or it will require a reinstall. That may have changed - I can easily double check. However, the issue you are having is that the Subscriber is unable to synchronize it's time to the hardware clock of the Publisher. This could be a bug or a hardware issue or just bad luck but in either case, you cannot install a Subscriber unless it can sync to the Pub. Time works like this (example is you use NTP):
Publisher is built. You specify an NTP source which happens to be an ISR router with address 10.10.10.10.
Before you install the Subscriber, you check the ntp status of the Publisher and it will list a local lookback first and the NTP server second. The NTP server should have a star next to it and indicate it is synchronized to the external source.
When you install the Subscriber, it will sync with the Pub which is synced to NTP.
Hailey
On CUCM 7.x the NTP is recommended and not mandatory like CUCM 8.
I have 2811 router, i think it cannot configured as ntp server.
Peterson
You're right, it's recommended - but highly recommended.  I have a 2811 router in my lab and it is configured as an NTP source for the CUCM cluster I have there.
Also, is this a hardware installation or a VMWare installation?  If this is a VMWare installation - this is a very common issue.
Hailey
Is a hardware installation on customer.
Can you send me you router 2811 configuration? I will configure the 2811 like NTP server on CUCM.
Peterson
ntp source
You will need to look at the install guide to confirm but I'm fairly certain this is correct. If you already built the Publisher without NTP, you cannot enable it after the fact. It must be done during installation. To enable it after the fact requires a rebuild of the system.
Hailey
allan.thomas
Level 8
Level 8
Please take a look at the following post by Rob, you may find it helpful and answer any concerns that you have:-
https://supportforums.cisco.com/message/1213842#1213842
Allan.
Hope this helps, pls rate helpful posts.
aalamgir
Talking about VMware, Just add subscriber IP address in publisher CUCM & it would sync its time with publisher during installation.
aalamgir
Talking about VMware, Just add subscriber IP address in publisher CUCM  & it would sync its time with publisher during installation. Or you may say that "  Register Subscriber in Publisher" while giving its IP address under System ==> Server==> add new.
