Tcd Server heartbeat
dvanzee
Level 2
Level 2
CM4.2.3sr3
I am receiving this alert from my publisher server RTMT-alert notification
At 13:31:32 on 10/16/2009 on node 10.XX.XX.XX.
Tcd Server heartbeat rate below 24 beats per minute.
Current heartbeat rate is 0 beats per minute.
I found a post online, which indicated that this error/alert is caused by the CCM.exe process, not receiving enough cpu time, the post also indicated that this problem could be caused by a hardware failure.
Can someone tell me how I can go about finding out what the root cause of this problem/notification could be?
http://www.gossamer-threads.com/lists/engine?do=post_view_printable;post=84175;list=cisco
gogasca
Level 10
Level 10
Heartbeat confirms that tcd.exe as a process is getting CPU time and further it confirms that a few critical threads inside tcd.exe are getting processing time.
You may open a TAC case fur further investigation
