TFTP fine not found
valides007
I have a bunch of 7940 phones working on CME.
when booting the phones, some of them got a displayed message saying TFTP file not found. I reset them and i'm still getting the same message. What is confusing me is that all these phones were working great a week ago.
Any ideas?
6 Replies 6
Jaime Valencia
what file are they saying it's not found??
javalenc
if this helps, please rate
java
gary.simpson
Is it to do with the Distinctive ring list?
When the phone boots, it looks for two files, RingList.xml and DistinctiveRingList.xml, where you should define available downloadable Ring Tones. Both files, as well as ring tone RAW files should be defined as TFTP files.
You can find more information as well as configuration examples in the "Configuring Ring Tones" section in "CME Configuration Guide".
Hope this helps,
Gary.
It doesn't say which file. It's just saying:
TFTP file not found
Turn on debug tftp events and it will tell you which files it is looking for.
And where this debug should be activated? On the router? or I can use CALLMANAGER TRACE?
Turn the Debug on, on the CME. There are about 4-5 files that the Phone will look for when it is first connected. With this debug turned on you will see which file the phone is looking for and whether it found it. All the files must exist on the Flash and be configured in the CME CLI as follows:-
tftp-server flash:P0030702T023.bin
tftp-server flash:P0030702T023.loads
tftp-server flash:P0030702T023.sb2
tftp-server flash:P0030702T023.sbn
tftp-server flash:P00405000700.bin
tftp-server flash:P00405000700.sbn
