UC 520
RKha
hello every one , i write to ask if the UC520 work in maultisite centrlized call processing deployment (1 main and 29 branches ) ?
Jaime Valencia
Q. Can the Cisco Unified Communications 500 Series be used for a multisite deployments?
A. Yes, the Cisco Unified Communications 500 Series can be used for multisite deployments
where call processing is distributed. Also for a small business with a few sites, the Cisco
Unified Communications 500 Series can be at a main site and support is provided for up to two
remote sites.
Q. Can multiple systems be networked together?
A. Yes, three to five Cisco Unified Communications 500 Series systems can be configured to
work together. If there is a requirement for additional site-to-site networking, the Cisco
integrated services routers are recommended for those deployment scenarios.
http://www.cisco.com/en/US/solutions/ns339/ns637/networking_solutions_products_genericcontent0900aecd806122df.pdf
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
ok thanx javalenc  to your respons , but the document didnt clarify if the CENTRALIZED deployment can do this or not , answer just for distributed .
i feel its not ....
paolo bevilacqua
Yes, it can.
