10-14-2008 07:10 AM - edited 03-15-2019 01:56 PM
Hi Chaps, easy question
UCM6 - is it a SQL backend database that is used? if so - during a new installation is it possible to host the sql database on an external (corporate) SQL server?
Thanks in advance.
Rod
Solved! Go to Solution.
10-14-2008 07:33 AM
no, windows versions use SQL, linux versions use informix.
cannot be hosted on any other server
java
if this helps, please rate
10-14-2008 07:33 AM
java
