unique problem. cp7911 flapping between data and voice vlan
lupemacias
have multiple CP7911s flapping between the data ahd voice vlan both when idle and during a call.
-Setup-
UCM 6.1(2)
Cat3750
CP7911
-Port Config Looks Like-
switchport access vlan 4
switchport voice vlan 512
Have upgraded and downgraded switch firmware. Have upgraded and downgraded phone firmware.
Phone log shows the following.
NOT 08:47:24.959415 CDP-D: vvlan changed --> New:4096 old:512 4096
NOT 08:47:24.964826 CDP-D: vlan Configured --> New:4096 old:4 :4096
NOT 08:47:25.008963 CDP-D: vvlan changed --> New:512 old:4096 512
NOT 08:47:25.014483 CDP-D: vlan Configured --> New:4 old:4096 :4
NOT 09:01:24.959628 CDP-D: vvlan changed --> New:4096 old:512 4096
NOT 09:01:24.965456 CDP-D: vlan Configured --> New:4096 old:4 :4096
Anyone have any ideas what may be causing this.
Giuseppe Larosa
Hello Lupe,
it looks like CDP communication is not working well.
To be noted that vlan 4096 as vlan 0 cannot be used for real switch ports they are reserved for internal use in switch.
You can see a circular sequence involving vlans 4, 512 and this 4096.
Also CDP messages are sent every 60 seconds but the first log lines are very close:
I would try to span the switch port to a port with a sniffer like wireshark to see the CDP messages sent by the switch
Hope to help
Giuseppe
I did that to see if I saw anything weird, but I didn't think to look for CDP messages in the capture. I'll do it again and look for CDP.
Weird thing is I don't change CDP settings. All CDP settings are default.
Thanks.
lupemacias
after speaking with TAC, this turned out to be a bug in the cp7911 & cp7931 firmware.
CSCsu47079
TAC hooked me up with SCCP_7911_7906_8-4-3ES4 firmware for the 7911. it's looking good so far. a workaround was to reduce CDP timer to 15.
