10-21-2014 08:12 AM - edited 03-17-2019 12:37 AM
I have an 8.6.2 cluster with unity connection 8.6. I am deploying a second cluster and am trying to use the Unity connection on the first cluster via a trunk.
I have configured a SIP trunk between the clusters with QSIG tunnelled protocol and am able to leave messages , however MWI doesn't work
I have also tried with an ICT trunk and same results.
I'm now stuck as i believe this should work but am not sure on MWI config.
The MWI numbers on the second cluster , what should they be, i have read that you don't actually need them??? i have tried with and without and nothing changes
10-21-2014 08:46 AM
I am not sure why you wouldn't need MWI numbers, I have a sip integration and I definitely use them.
Few things to check
1. Your sip trunk security profile needs to have the ff: checked
accept out of dialog refer
accept unsolicited notification
accept replaces header..
2. The inbound css on your sip trunk to unity connection needs to have access to the pt of mwi number.
3. keep it simple, use only sip trunk, I am not sure why you need qsig tunnelling, unless you need it for specific requirements, I will only use a sip trunk..
4, have you tried dialling the mwi number form an ip phone? does it work?
10-21-2014 11:50 AM
1. I will check
2.The unity connection integration to first cluster is actually SCCP but I will check the CSS on the ports
3.If you read all the documentation it all mentions using QSIG tunneling to carry MWI between the callmanager clusters
4.yep
10-23-2014 06:51 AM
So i set this up in my lab to replicate what i wanted to achieve
UnityConnection 8 ---SCCP----CCM862SU2 -----SIP Trunk ------CCM862SU2
Basic config on the sip trunk , just added QSIG as the tunneled protocol.
It worked first time.............. Can't see why this doesn't work on the production cluster.
You don't need MWI configured on the second cluster , it all just seems to work.Will post again when i figure this out (hopefully)
10-24-2014 01:29 AM
Mark,
Thanks for the update. (not sure if you remember me though :))
10-29-2014 04:08 AM
sorry deji didn't recognise you're name , yes i do remember you , trying to forget RBS :-) though
anyway , sorted my issue, made a stupid mistake on the mailbox configuration.(Wrong phone system) once i changed that it worked a treat.Very easy setup.
10-29-2014 04:11 AM
Thanks Mark for the update (+5). Hope you are well
