Unity Connection: Error when I want to see a user greetings
guilhem.perez
Level 4
Level 4
I have an error when I click on user greetings on Unity connection administration:
exception
javax.servlet.ServletException: Unparseable date: "Jan 1 1972 1:00AM"
java.text.ParseException: Unparseable date: "Jan 1 1972 1:00AM"
Does somebody know what is it about?
Thanks.
Best regards.
aghaznavi
Level 5
Level 5
Workaround:
Set machine to US locale.
If that doesn't work, then try the following:
1. Run regedit, locate:
HKEY_LOCAL_MACHINE\SOFTWARE\Cisco\Resource Manager\CurrentVersion\Daemons\IDS_CronDaemon
2. Now edit the "Args" to add " -Duser.country=US -Duser.language=en " just after "-Xrs" and just before "com.cisco.nm.mdc.ids.config.daemon.cron.CronDaemon"
From (removed most of the classpath for clarity):
-cw C:\PROGRA~1\CSCOpx -cp C:\PROGRA~1... -cw:jre C:\PROGRA~1\CSCOpx\MDC\jre -Xrs com.cisco.nm.mdc.ids.config.daemon.cron.CronDaemon
to:
-cw C:\PROGRA~1\CSCOpx -cp C:\PROGRA~1\... -cw:jre C:\PROGRA~1\CSCOpx\MDC\jre -Xrs -Duser.country=US -Duser.language=en com.cisco.nm.mdc.ids.config.daemon.cron.CronDaemon
3. Now restart the daemon manager.
What this does is tell the cron daemon's java virtual machine to use US & en locales.
Note, this did cause the last updated time and date on the autodownload page to contain a formatting error which was easily fixed by running a "Check Now".
Further Problem Description:
Noticed in the code the use of default locales for cron scheduling. The US locale should be explicitly used.
7 Replies 7
aghaznavi
Level 5
Level 5
Workaround:
to:
Thanks very much for your post.
I've changed machine to US locale. It doesn't work.
But when I run regedit, I can't locate:
Could you help me?
Thanks.
I'm suspecting you are talking a similar issue but a totally different product. Your tips seems related to Cisco Works ("Resource Manager" in the registry path).
/David
d.haeni
Level 4
Level 4
Did you find a solution in the end?
I'm having a similar issue when clicking on "Edit Greetings" of a particular user:
HTTP Status 500 -
type Exception report
message
description The server encountered an internal error () that prevented it from fulfilling this request.
exception
javax.servlet.ServletException: Unparseable date: "Dec 31 1990 1:00AM"
Any help is greatly appreciated
/David
PS: I'm on Unity Connection 1.1(1)SR1
i solve this problem.
I change locale (US instead of french)
I change also Locale default to US
Then I reboot Unity server.
Salut Guilhem,
I changed three things on the Unity Server:
1. System Settings -> VMS Configuration -> System Default -> English(United States)
2. Start -> Settings -> Control Panel -> Regional and Language Options -> Regional Options -> "English(United States)" & "United States"
3. Start -> Settings -> Control Panel -> Regional and Language Options -> Language -> Details -> Default Input Language -> "English(United States) - EN"
Unluckily, after a reboot of the server I still had the same effect. Did I miss something?
/David
check in Regional and Language Options > advanced,
default user account settings, apply all settings to the current user account and to the default user ptofile is checked.
If not, change it and reboot
