Unity Live Record
scotteturner
I have unity live record set up, but I have a few questions about it.
1. When you are getting near the end of the record time, does you hear a beep or recording telling you it's done recording?
2. If there is a beep or recording, do all parties on the line hear it?
3. If no beep or whatever, I assume it will just stop recording and not overwrite the start of it?
Scott
Brandon Buffin
Scott,
To my knowledge there is no beep to indicate that recording has stopped. Unity will just stop recording after the time you have set for the maximum length of messages in Unity admin. There is a periodic beep while recording is taking place that all parties can hear. The interval and duration of this beep can be adjusted with the Advanced Settings Tool
Hope this helps. If so, please rate the post.
Brandon
