VG200 Login
Mojo1
What are the inital commands to login to a VG200 from the command prompt?
Rob Huffman
Hi Bill,
Have a look at this doc;
Cisco VG224 Voice Gateway Software Configuration Guide
Configuring with the Command-Line Interface
http://www.cisco.com/en/US/products/hw/gatecont/ps2250/products_configuration_guide_chapter09186a00801d7e64.html#1039811
Hope this helps!
Rob
What I need to know is from the C:\Documents and Settings\lamb> what do I type in first to get to the gateway? What you sent me does not show this.
The answer is telnet ip address of gateway
