Will a Voice Router behind a Company PBX work.
jennyjohn
I have a voice router (2811 with 12.4(6)T Advance IP Services IOS) connected behind a PBX. The PBX uses a 3 digit extension number while the Cisco phones use a 4 digit extension number. Can both work together?? Will this setup work?? (Diagram Attached). Also please find the configuration of the voice router below. All suggestions are welcome, Thanks.
(This setup is only for test purpose and is not the final solution).
Current configuration : 1749 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip cef
voice-card 0
dspfarm
interface FastEthernet0/0
ip address 10.10.10.252 255.255.255.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.10.10.252
interface FastEthernet0/1
shutdown
duplex auto
speed auto
interface Vlan1
no ip address
ip http server
no ip http secure-server
control-plane
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
dial-peer voice 412 pots
description *** Analog Phone 412 ***
destination-pattern 412
port 0/1/1
dial-peer voice 100 voip
description *** Cisco IP Phones ***
destination-pattern 1...
session target ipv4:10.10.10.110
dial-peer voice 1 pots
description *** To PBX ***
destination-pattern ........
port 0/2/0
line con 0
line aux 0
line 66
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 4
login
scheduler allocate 20000 1000
webvpn context Default_context
ssl authenticate verify all
no inservice
end
Marwan ALshawi
i will assume the numring rang for ur pbx is between 400 to 499
so do the following on ur router
destination-pattrent 54..
port 0/2/0
forward-digit 3
and make a route pattren on ur callmaneger
with pattren 54XX pointing to ur gateway
try it and let me know
in addetion make
deffrent route pattren for ur analog phone
which is 412
by the way in the above config u didnt put forward-digit 3
in this case after ur router match ur pots dial peer will forward nothing
so put forward digit 3
or u can use the following translation profile in incoming direction with ur dial peer
voice translation-rule 1
rule 1 /^.*\(4..\)/ \\1/
voice translation-profile to-pbx
translate called 1
but this is a bit advanced
so try the forwarddigit option and let me know if worked
Rate if helpful
ecornwell
Level 2
Level 2
Do you have an example of your dial-plan? We currently have to send all our external calls out our PBX and have the majority of our userbase still on our Nortel PBX and we have no problems.
Your biggest challenge will be if you have an over-lapping dial plan. In my opinion it would be beneficial to set your gateway up as MGCP and have CallManager handle the routing. You can get much more granular very easily.
