Bookmark
Subscribe
12288
CUCM 7.0.2 Directory Numbers (Internal Caller ID)
     I am trying to mask the internal caller ID on Call Manager 7.0.2 from showing the directory number. In the phone's Directory Properties page, I have replaced the line 1 Display (Internal Caller ID) to show Private (0000). When I call a telephone from my station the Internal caller ID that show is Private (0000) (4406). How can I block or mask the real directory number from showing up?
2 Accepted Solutions
Go thru this link, it will help you understand what you need
You can look the specific doc for your version but the theory is exactly the same
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
From what I understand you are saying, both of your devices are in the same partition and you are trying to restrict/modify number presentation between these to lines/phones. I don't think this will work as you will need to have the phones in 2 seperate partitions to allow the Translation pattern to do its thing.
In short you should have something like this:
     Phone 1 --> Directory Number '7024' in Partition 'PT1' with CSS 'CSS_1'
     Phone 2 --> Directory Number '7201' in Partition 'PT2' with CSS 'CSS_2'
     CSS_1 does NOT contain the Partition of 'PT2'
     CSS_2 does NOT contain the Partition of 'PT1'
     A Translation Pattern of 'TP_1' with Pattern '72XX' in Partition 'PT1' with a CSS of 'CSS_2' (and Calling Line/Name restrictions in place)
     A Translation Pattern of 'TP_2' with Pattern '70XX' in Partition 'PT2' with a CSS of 'CSS_1' (and Calling Line/Name restrictions in place)
Also keep in mind that you have the CSS applied appropriately to the Device and/or Line of your Directory Numbers (as CUCM concatenates CSS's when they appear on a Directory Numbers Device and Line).
Hope this helps,
John D.
9 Replies 9
Not sure what have you done so far but you can try with translation pattern: XXXX where you only change Calling Party Transform Mask to 0000 or whatever you want to use.
Ok
I setup a Translation pattern of XXXX
with a Calling search space of Internal
I checked Use Calling Party's External Phone Number Mask
Set the Calling party transform mask to 0000
Is this correct? If it is, it did not work.
You don't need External Phone Number Mask, second use traces to check if you hit this translation pattern. For testing I would use separate CSS and partition to make things clear.
java
java
create a partision called internal-1
assigned to to your translation patteren
in the device you are calling from make sure that the internal-1 partition listed first one ( before any internal partiton)
make sure the urgent priority is checked in the translation pattren setting page
also make sure the CSS of the translation pattren has access to your internal phones
good luck
if helpful Rate
Ok. This is what i have done:
I have created an Testing_PT (Partition) and a Testing_Campus_CSS (Calling Search Space).
I place the Testing_PT in the Testing_Campus_CSS. This is the only Partiton in the Testing_Campus_CSS Calling Search Space.
The Translation Pattern created has the following attributes:
                    Translation Patter:                 XXXX
                    Partition:                              Testing_PT
                    Calling Search Space:           Testing_Campus_CSS
                    Calling Line ID Presentation:  Restricted
                    Calling Name Presentation:    Restricted
I have two telephones ext 7024 and 7201 both in the Testing_PT and Testing_Campus_CSS.
Both telephones can call each other and the directory number for each telephone shows. Can you guys see anything wrong with what I am doing?
Hope this helps,
John D.
Hi Guys;
I did set my RP as John explain and so far it's working.
The only problem I have is when I set my Traslation Pattern name = 7024 (for example) is working but when I replace it by 70XX it's display the extension .
Did some one have this problem before ?
Ryad M
Woow, this was very helpful for me. Tks!
