07-30-2008 05:54 AM - edited 03-06-2019 12:31 AM
I have 877W router.
It is connected to ADSL to the IP-address 1.2.3.4.
To the same address is routed block of IP-adresses 5.6.7.128/15
I configure to Interface Vlan1
IP address 10.0.0.254 255.255.255.0
and
IP address 5.6.7.142 255.255.255.240 secondary
Now access from Internet to all hosts connected to block of IP address (5.6.7.x)are possible.
Access to Internet from network addresses 10.0.0.x and from WiFi are working.
But i cannot access from hosts 5.6.7.x to hosts 10.0.0.x.
Please help me to fix this problem.
Solved! Go to Solution.
07-30-2008 06:36 AM
Make sure the default gateway on devices with 10.0.0.x is 10.0.0.254
while
devices with 5.6.7.x, default gateway should be 5.6.7.142
HTH,
__
Edison.
07-30-2008 06:36 AM
while
HTH,
__
Edison.
07-31-2008 03:11 AM
Many thanks for your assistance.
I have connected 2 devices the 10.0.0.x network but they was configured for other router.
Unfortunately these devices cannot be configured and i have been compelled to reconfigure CISCO.
07-31-2008 04:50 AM
You can configure the other router to point to the Cisco router for packets destined to 10.0.0.x
In Cisco, you can accomplish this with:
ip route 10.0.0.x 255.255.255.0 [gateway].
HTH,
__
Edison.
