TCL Script for shutting interfaces
steve.orphanos
I wanted to know if anyone can help me create a TCL script that can shut down interfaces when the script is executed.
7 Replies 7
Joe Clarke
What version of IOS are you using? What arguments should the script take?
The IOS version is 12.2(33). I would like to create a script that when executed would execute the following commands.
Interface Gig 1/1
Shut
Interface range Gig 2/1 - 6
Shut
Interface Gig 2/20
shut
Interface range Gig 2/23 - 24
Shut
Then have another script to turn those interfaces up.
This should do it for you:
Switch#tclsh flash:bounce-ports.tcl shut
Switch#tclsh flash:bounce-ports.tcl noshut
Do i just copy the file bounce-ports.tcl to the cisco router? If so where does the file get placed?
Thanks again for all your help
You can copy it to the local flash of the switch, or leave it on a network server. For example, the script can be run directly from TFTP:
Switch#tclsh tftp://10.1.1.1/bounce-ports.tcl shut
I found a stupid typo in the noshut case. Here is a fixed version.
Thanks again for all your help. I greatly appreciate it.
