ASA 5505 remote-vpn help
niko.hartung
Out-of-the box configuration. Changed the internal ip range, DHCP pool and ASDM config. Then I ran the VPN wizard to connect a VPN client. I cant establish a tunnel what so ever. Find attached the config and the log.
Thank you in advanced for you help
Niko
8 Replies 8
srue
Level 7
Level 7
I pulled this off of a working config, 5505 7.2(3)
ip local pool vpnpool 10.x.y.1-10.x.y.10 mask 255.255.255.0
crypto ipsec transform-set AES256_SHA esp-aes-256 esp-sha-hmac
crypto dynamic-map DYNAMICMAP 5 set transform-set AES256_SHA
crypto dynamic-map DYNAMICMAP 5 set security-association lifetime seconds 7200
crypto map CRYPTOMAP 5 ipsec-isakmp dynamic DYNAMICMAP
crypto map CRYPTOMAP interface outside
crypto isakmp enable outside
crypto isakmp policy 5
authentication pre-share
encryption aes-256
hash sha
group 2
lifetime 86400
crypto isakmp nat-traversal 20
group-policy GROUPPOLICYNAME internal
group-policy GROUPPOLICYNAME attributes
dns-server value 10.x.y.z
vpn-idle-timeout 120
vpn-tunnel-protocol IPSec
split-tunnel-policy tunnelspecified
split-tunnel-network-list value splittunnel_acl
default-domain value domain.org
split-dns value domain.org
tunnel-group VPNGROUPNAME type ipsec-ra
tunnel-group VPNGROUPNAME general-attributes
address-pool vpnpool
default-group-policy GROUPPOLICYNAME
tunnel-group VPNGROUPNAME ipsec-attributes
pre-shared-key *
isakmp ikev1-user-authentication none
the very last line disables xauth...
Thanks for your quick response. I've tried to disable xauth already but no luck.
based on your configuration, you have to set the group name (in the cisco vpn client) to 10.0.0.0
is that really what you want?
you also don't have nat-t enabled, which might be causing issues.
if you don't want xauth, just add that last line under the tunnel-group ipsec attributes.
Hi Niko
Attached config is a mess, attach the config you made after analyzing srue's sample RA-VPN config
Niko
Assuming that this is a start from scratch (you newly configure this device) and this config is messy (webvpn policy etc), I suggest you to load factory defaults, change your Lan IP and subnet, then follow this step by step guide to configure VPN
http://www.petenetlive.com/Tech/Firewalls/Cisco/c2svpn.htm
I'll give it a try.
thx
